pepecat
- Dodging the Buzes in Brum
So , my n+1 - though it's actually an n+1/2 an excuse for a bike......
Anyway, it's rather old (80s design?) and some bright spark at peugot decided to make the seat post clamp the same bolt as the one that tightens and keeps the rear cantilever brake in place. Wonderful.
I put a new seat and seat post on the bike, cos the original seat post was about 10cm long (seriously) and not long enough to raise the seat to my height. The last two times i've ridden the bike, I've raised the set to my height, made sure the back brake is in the right place and tightened the bolt as hard as i can. If i don't adjust the back brake properly, it doesn't work....it gets too tight and you can't pull the lever.
And off i go on my bike.......and as i ride, something looses the bolt, and my seat gets gradually lower and lower.....and then moves from side to side with pretty much every push of the legs (left right left right....seat left right left right)....
Is it use of the back brake that is loosening the bolt? And is there any way i can separate the dual action bolt to leave the seat alone?
