Scott Speedster vs Speedster gravel disc difference?
Peet30
Regular
Hey Guys! Im interested in getting one for commuting and also graveling but im not sure which one to pick.
Can anyone tell me what´s the difference between those two bikes? Thanks
Greetings
Peter
Cycleops
Accra, Ghana
Could you please provide a link to the exact bikes so we get the correct specs and years.
I suspect it'll be just frame clearance and fatter tyres on the gravel plus lower gearing.
Dogtrousers
Kilometre nibbler
Yup, I think you're right.
I did a quick google and the speedster gravel version comes with 45mm tyres and the not-gravel speedster with 32s. It doesn't actually give clearance figures but I think we can infer that the gravel has more clearance.
The gravel has a subcompact 46/30 chainset and wide 11-36 cassette
The notgravel has a compact 50/34 and more standard 11-32
These were the 2 bikes I looked at (which are not necessarily the right ones)
Gravel https://www.scott-sports.com/gb/en/product/scott-speedster-gravel-20-bike
Notgravel https://www.scott-sports.com/gb/en/product/scott-speedster-20-bike
Dogtrousers
Kilometre nibbler
Gearing wise the gravel will lose a bit at the top end, (for bombing along on flat roads or downhill) and will gain a lot at the bottom (for grovelling uphill).
P
Peet30
Regular
Thanks for your help guys!
When im between the size S and M which one should i choose? The 52 or 54 size?
Cycleops
Accra, Ghana
Usual advice on here is go for the smaller size. Me, I prefer a bigger frame. Try if you can.
Neither are available for the gravel and 54 only for road in your links.
If buying from a shop, try both for size and comfort
Jameshow
I wouldn't be surprised if they were the same bike, and your paying a £200 premium! For wide tyres and a bigger spread of gears?
