Yellow Saddle
- Loch side.
Thanks for that link.
I want to research this a bit. I am skeptical that a fork for instance, made in pure silver, is strong enough. I used to do a bit of silver soldering and although the rods were of an silver alloy, they were certainly soft - too soft for fork tines. That set in your link has a pure silver mass of 3kgs, I think the entire set will weigh much more, indicating some steel in there and more than just the knife blades. I'm mulling this over. Any antique/silverware experts here?
Aha! Thus "plate" doesn't necessarily denotes electro-plating or hot dip. Do you know if sterling silver is strong enough for fork tines or the slender bit between the handle and the head, whatever that part of a fork's anatomy is called?Sterling silver, as used for making stuff out of is 92.5% silver apparently. This is hard/strong enough to make cuttlery, jewellery, coins, teapots etc out of . Silver plate is a much cheaper underneath material with a thin coating of silver - example would be EPNS - electro plated nickel silver. Slightly confusingly the term "plate" can be, and certainly was historically, used to mean actual silver goods (ie 92% stuff), not just what we now mean by silver plate ( thin coating onto something cheaper)
Aha! Thus "plate" doesn't denote electro-plating or hot dip. Do you know if sterling silver is strong enough for fork tines or the slender bit between the handle and the head, whatever that part of a fork's anatomy is called?
I will as soon as you tell me where my parents kept their magnets !@jefmcg would you kindly perform a magnet test on that beautiful tureen of yours?
Doh! Stuck to the fridge of course. (That was close; I was seriously considering dismantling some old speakers that are destined for the tip.)
Not magnetic![]()
It is dentedIt would have been dented and much thicker had it been made from such a soft metal.
Some labour I am currently undertaking ....
View attachment 144545 View attachment 144544
(this thing is from a Victorian pub, I think. It's quite large - 46 cm/18" in length)
That's not good enough.
It looks like the lid off a Victorian chafing dish.
Yeah, this is an object that my father knew about. He said meat cover.I trhink it's unlikely to be a chafing dish cover - the dome is a bit too high. I'd say more a dome from a meat server.
whatever people ate in those days
I've got shed envy, I want to move to the new house and start building.
