There are quite a few sites that offer free route planning in addition to a paid for version; software as you'd expect changes frequently and you may swap from on to another as they evolve.
At the moment I normally use the free version of
www.alltrails.com (was GPSies) to create the course and add to my old
Garmin 810 via usb. The user experience is very similar to
www.ridewithgps.com, but with the added bonus that you can add your own notes in the form of a 'waypoint'; like 'café' or 'bikeshop', a feature that is no longer free with
ridewithgps; hence my switch to Alltrails. One handy feature I like is you can toggle between 'hiking-cycling-driving' when creating, so you can switch to 'hiking' if you want to take a shortcut over a footbridge for example then back to driving if you want to stay on roads. There are two cycle focused modes, '
Bike touring' may include a smooth trail where as
'Road biking' will be on paved roads and paths that support bicycle access.
I live in a London Suburb, I seldom use
Garmin Connect, as you'd expect since I bought my 810 in 2013 it has improved but it has been consistently behind other free course planning software. It still shares routing with runners so it will still often send you the wrong way around roundabouts, the wrong way down one way streets and take you down tracks even if you have selected 'follow roads', overriding this on route effectively going 'off course' often causes the 810 to crash; less of an issue in rural areas which have less one way streets and roundabouts of course.
I have been pleased with my Garmin and I was updating it I'd be happy to buy another, although there are quite a few others that have their followers;
Wahoo especially also look impressive. For what it's worth if I was looking at the current
Garmin range, features wise the
Edge® Explore would be a consideration as I am really only interested in the mapping; although the extra battery capacity of the
830 would probably sway me (upto 20 v 12 hours). Yes the 830 is more of an investment but my old 810 has lasted 8 years which is not bad for a piece of tech'; which for me would also be a consideration when justifying how much I am prepared to treat myself. The
530 is cheaper and also has 'upto 20 hours' battery life, I do find the 830 touch screen far more intuitive to use than the 530's buttons.
Some have referenced stability, over the years I find the following has helped. Whatever software I use to compose a route in each case if composed on a pc when I transfer it to the unit I do it via usb (
make sure it is the genuine lead, copies that seem to fit perfectly may not transfer the data fully) not via Bluetooth, occasionally with the latter it may not transfer the data as created and be less stable in use potentially crash during navigation. In addition I only ever transfer the data from the software it was created from, as opposed to say a route initially created with RWGPS then imported into another like Garmin Connect to edit, before transferring that to my Garmin. Along the same lines if I want to use a course from someone else I will normally use that as a reference only and create it 'fresh' for myself
