andrew_s
- Gloucester
What is your experience of using the Bagman with the QR? I have heard of people having problems with the springs and the grub screws although the screws can be replaced with allen bolts apparently.how far does the Bagman place the bag? It probably depends on the saddle and how far you sit forward I suppose.
I've got two.
The one on the work bike, mostly used with a Pendle, is one of the early versions, and I did have problems with the support coming out of the saddle rail clamp. I fixed it by putting a dimple in the sides of the rod with a dremel, dropping a ball bearing down the hole, then screwing the loctited grub screw back in. I used a ball bearing because it should be harder wearing than the end of the grub screw, and it would self-centre if the dimple wasn't in quite the right place. It's not shown any signs of moving since.
The other is a fairly recent model (13 months ago, ish), used with a Camper Longflap (usually heavily loaded) or a Nelson Longflap on the touring bike. That hasn't given any problems so far.
I don't find any particular effect on the handling provided that I keep my bum on the saddle. If I get out of the saddle and rock the bike, the weight tends to keep the bike going and needs a bit of a pull to stop it. It doesn't take long to learn to step from side to side rather than rock the bike.
On a rough track with a heavy bag, there is a fair amount of bounce from the springy support - enough to move the outside end of the support by about 4". Not really noticeable, but apparently looks fascinating to other riders.
Bagman and Camper Longflap with weekend camping gear.
