Saddle.
gavroche
gavroche
Getting old but not past it
North Wales
With reference to changing the saddle I have a specialized diverge with the same access slot to the adjusting screws. I want to change this to a charge spoon (my comfort saddle) would I need to change the saddle mounting brackets do you know?
My Specialized saddle has a slit in the middle so you can access the adjusting screws. I also have a charge spoon but can't use it as it is solid all over so not possible to adjust. Hope this helps.
Drago
Buy a new bike.
JD42
Hills are nature's way of culling the weak
Brizzle
Just had a play and you can fit it. Takes a little patience but set the front screw to desired height. Fit saddle then tighten rear screw to the correct pitch. Fiddly getting it to your desired level but it appears to have worked.
