Cheapskateianrauk said:Sudocrem is my recommendation
Tynan said:prevention better than cure is the watchword on this one!
and make sure your saddle and position is right before you do the ten days
good pair of proper padded shorts, bib if poss
Crankarm said:Savlon.
Vaseline doesn't have any antibacterial or anti-septic properties. When I used it briefly it was ok at first then caused nasty sores. Went to see doc. Doc said stop using it, as it is not suitable for the kind of use I was putting it to. Vaseline traps sweat and bacteria. Try Savlon instead. I have and it works for me. Apply Savlon on a clean under carriage area before you go to sleep. Soaks in over night. You can apply just before riding, but I'm not keen on the slippy feeling in my groin whilst cycling.
Haven't tried the other creams mentioned.
.bromptonfb said:have you read the link? have you read her quals? vaseline has natural antiseptic properties...i think
