threebikesmcginty
Corn Fed Hick...
- ...on the slake
Jimbo's quoting his own posts now ... quite clearly a nutter
Go for a ride in the nude and make a note of whereabouts your anus leaves a stain on the saddle. That is more applicable than the distance between saddle nose and handlebars.
Jimbo, you seem to be stuck on the fact you move around the saddle a lot & not actually registering that small position changes the centre point that you're moving around is the key here. If you move the saddle to far forwards by 5mm while you may be able to find a comfortable position when cruising you may well find that come to a hill you're rubbing the back of your legs on the saddle & thus you end up in the wrong position.AND... I can guarantee to everybody that on a 50 mile ride, you WILL without realising, shift your position on the saddle more than 5mm back and forth.
You will sit differently when climbing and you will shift back on the saddle when freewheeling.
Can't believe you've got Col to fall for your wicked ways Mac,always thought he had more sense than that![]()
I haven't actually done any measuring, I just looked at my saddle and noticed it was further forward than I remembered! It was then that I recalled thinking it was about time I started sitting on my sit bones rather than effectively on my perineum - ouch!![]()
It must be Jimbo's skidding on bikes that has made MacB abandon his own thread which is a shame after I did some homework and extra reading.
I've a related question too - has anyone ever had a professional bike-fit, did you benefit from it and was it worth the money? I'm thinking about it, It's expensive but long term might be for the good and interesting too. I've had a look around and there's one that I've seen some good reviews of called 'Bike Dynamics', not too far from me either.
Teef will remember well nursing me through my first century and, when my right knee was giving out, sorting out moving my, ridiculously far back, saddle forward.
I did (see post #6), but IME, it provides a good starting point and not the "perfect" solution. In my case after raiding the parts bin and swapping bars, stems and saddles from other bikes, I found that I preferred to be further back on the bike and preferred the slightly quicker steering with a shorter stem.It must be Jimbo's skidding on bikes that has made MacB abandon his own thread which is a shame after I did some homework and extra reading.
Forgot all about that actually - but I do remember the speed for the last 1/2km and the grin on your face as we hit the City!
Seems like only yesterday...
