I think it's because friction DT shifters are more common than indexed ones. The era of the indexed DT shifter was relatively short, before they were superseded by brifters and they never really dominated the market.Why the fixation on friction shifters ? Both my old Dawes and Falcon 'team banana' have indexed [rear only] downtube shifters and work very nicely thank you.
Because once you're used to them they just work.Why the fixation on friction shifters ?
Don't need to get used to indexed and actually they lasted quite a long time on road bikes.Because once you're used to them they just work.
We get enough threads about problems with indexed gears here, problems that didn't exist on DT friction shifters.Don't need to get used to indexed and actually they lasted quite a long time on road bikes.
Yep. I was having a problem with indexing drifting on a folding bike each time it was folded. I replaced it with a friction shifter and it's dribblingly gorgeous to use. I hadn't noticed how much control/flexibility I'd lost from not being able to feel the rear mech.We get enough threads about problems with indexed gears here, problems that didn't exist on DT friction shifters.![]()
It's been a little while since I used friction shifters but you're right, you do have a lot more control and flexibility.Yep. I was having a problem with indexing drifting on a folding bike each time it was folded. I replaced it with a friction shifter and it's dribblingly gorgeous to use. I hadn't noticed how much control/flexibility I'd lost from not being able to feel the rear mech.
The thing that's often handy on a folding bike (and probably would be on any commuting bike) is that it is possible to shift at much lower cadence by pushing the lever beyond the usual position for the gear and then trimming back. It's not advisable, but it is possible and it's nicer on my knees than mashing!It's been a little while since I used friction shifters but you're right, you do have a lot more control and flexibility.
