Rose bike
paulmcparland
I am thinking of ordering a Rose CL on line, but not sure of the sizing. I am currently riding a 54cm Trek, but Rose are recommending a51 cm? Any advice appreciated. Seems a tad small for me?
Andy-56
Regular
I would go with what they tell you, (presumably you've given them your dimensions?) if it's wrong you can always return the bike and opt for the larger size which they will arrange as part of the service.
Compare the geometries, different manufacturers measure different bits to get the sizing label
I went with the size they told me after the guy asked me my height. The size was spot on for me. I wouldn`t want the hassle & cost of returning the bike.
Height is not enough information to decide the frame size.
The guy asked me my height and inside leg, I should have said. I understand there are all sorts of measuements and geomotries that can be used depending on how specific the fit needs to be. When I have asked staff in bike shops they have always said height and inside leg.
Paul, I got a 53cm and I`m only 5` 8". I don`t know if the fact that my bike has flat handle bars makes any difference. I guess that aspect is more to do with reach.
Tin Pot
I'm 5'8", 29" inseam and ride a 51cm Cinelli experience frame with a shortened stem 110mm down to 80mm. Retul based fit.
Thats not to say 51rose whatever model is right or wrong for you, but to show it could be.
This is the issue with online purchase where you cannot realistically try the bike for size.
Cinelli experience has a 53 or 54.5cm top tube depending on which measurement you look at.
The 51cm bit comes from the seat tube on the medium bike
http://www.cinelli.it/site/index.ph...e.tpl&vmcchk=1&option=com_virtuemart&Itemid=9
Rose may measure a different part of the bike to get their 51cm size label
huwsparky
Llangrannog
I'm between a 53 and 55cm too with a Rose. They have suggested a 53cm from the info I have given them 5ft 8inch with 83.5cm(I think) Inseem which apparently means I have long legs for my height.
The 55cm has the same effective top tube as my current 54cm Giant. I'm probably going to go for their advice but the only thing holding me back is the shorter top tube which the 53cm would have. Pretty sure though, for me either would do but I don't want a stem shorter than 10cm so I'm gonna opt for the 53cm with spacers to raise the front to my liking.
