jay clock
Massive member
- Hampshire UK
I have had problems with Conti tubes and stopped using them. Cheap online tubes with slick valves are fine for me.
Are these one-piece? I use Scwalbe tubes and am now vaguely terrified by the prospect of the scenario discussed in this thread!Schwalbe
Out of seven Conti tubes over the winter, 3 have had the cores come out. One came loose weds morning actually. Screwed back in fine.
It's annoying. I've found that leaving the valve caps almost loose helps.
Its the same for me usually but I saw a pack of Vittoria which looked the same (smooth stem) but they had the removable core as I found out fortunately I had a second tube but stillMichelin for me. Smooth stem, no threaded collar, and leave the valve cap off anyway.
