flake99please
We all scream for ice cream
- Edinburgh
Have you given the pinion gear system any consideration?
Thanks, I always wondered how they came up with the Max difference between chainrings.It may not be exactly 26 teeth but it's very close to that.
The depth of the front cage limits the maximum difference between chainrings.
Put the chain on the big chainring and measure the gap in mm between the chain and the bottom of the cage.
Divide by 2 and that's the maximum number of teeth possible between the big chainring and small.
Exceed that number and the chain starts to rub on the bottom of the cage when you drop onto the small chainring.
If you've seen any posts on running quad chainrings then that was only possible by combining two cages to make one extra deep one.
Basically you cut the bottom off one cage and the other cage just behind the pivot points, now solder the two parts together to make an extra long/deep cage.
The "mountain tamer quad" adapter then lets you use a sprocket as a fourth chainring for something like 53-39-30-18.
This was from the days when 32 was a big sprocket.
Luck .........
How long does it take you to change a cassette?Or to put that another way, you have to choose between Rohloff reliability or having the inconvenience and time consuming activities of ordering and fitting replacement components at regular intervals, during some of that time your bike will be out of service.
A lot longer than it takes me to do the annual oil change on a Rohloff, and I can programme oil changes to a winter month to suit my convenience rather than when it becomes necessary due to wear and tear of chain or sprockets.How long does it take you to change a cassette?
I fear you may be doing something wrong.
On the contrary, I know I am doing something right!
I don't know about you but I can change a rear cassette in under 10 minutes.
Doing an oil change on a Rohloff takes around an hour to do it properly.
Except when the hub rim cracks around the spoke holes on a Rohloff it has to go back to Germany for assessment and repair. This happened to us yesterday and we're looking at 8 - 10 weeks before it's returned and the wheel rebuilt. This is a known weakness on the hub, especially for tandems, and the hub, from new, has a retaining ring to prevent the spokes pulling through (check out below and the pics on the SJS cycles site) which is a bit of an afterthought and suggests that they should have re-engineered the hub by now to overcome the admitted weakness, especially for the price. All the good points about static gear-changing and everyday ease of service - undeniably true - until it goes wrong. Toms Bike Trip site puts it well I think: https://tomsbiketrip.com/touring-bike-faq-5-derailleurs-or-internal-hub-gears-rohloff/Or to put that another way, you have to choose between Rohloff reliability or having the inconvenience and time consuming activities of ordering and fitting replacement components at regular intervals, during some of that time your bike will be out of service.
