With a bent trike, you soon run into the limits of what a derailleur setup can do.
The limit for a front derailleur is 26 teeth, so 22-36-48 gives you a maximum range of 218%.
The limit of a rear derailleur is around 49 teeth, so add 2 for luck so that the chain rubs on the derailleur when running small-small.
51-26=25 so an 11-36 block works, which gives you a range of 327%.
Combining them give you a total range of 713% or 15"-107" on a 26" wheel.
It doesn't matter if you use a 7 block or a 13 block at the back, without modding the rear derailleur to cope with more teeth, that the maximum range of a pure derailleur setup.
Now you know why I started to look at none pure derailleur setup when I had my latest trike built.
I was after 10"-130".
With my Rohloff and HSD with twin chainrings setup I ended up with 9.4"-179.4" or 1905% .......
Luck ........
