Anyone know what size allen key I need for the remote lockout cable anchor bolt on my forks? It looked like a 2mm, and I managed to attach it using this size, then (being a bit of a doofus and in a bit too much of a hurry) realised I hadn't done it properly, so went to undo the bolt again, when it became apparent that the 2mm key was actually a bit too small. A 2.5mm is too big, so I presume there is some preposterous imperial fraction-of-an-inch size that I need? Either than or I rounded off the bolt head when I tightened it - but that doesn't seem likely as I didn't use a lot of force .
