Sloth
Paddle or saddle? Is it a canoe or a bike?![]()
Oops! corrected, I'll check but it's not amphibious...
Edit: Although it's been raining so much here of late I may actually need a paddle!😢
Yes it does, 559x17!but it seems not
Will a 40mm tyre fit on a 17mm rim ok thought (no idea hence asking)
Yes, they’ll be fine. They are MTB rims, He could go up to 2.1” according to the label.Will a 40mm tyre fit on a 17mm rim ok thought (no idea hence asking)
In fact, it tells you everything you need to know. Min tyre width 1.5", max 2.1", 559 rim size. There's no more you can know!but it seems not
i had those tyres on mineThanks, sorry for the daft questions but I am new to all this
So, if I want a tyre that's more for road use then I could fit a 1.5" width as a minimum but what is the min/max profile depth (height from the rim to tyre surface) that I can have? I don't want the tyre to look silly on a MTB frame if it's too low a profile I suppose?
