Road to Gravel Conversion
Cheshire
Thanks! 32 might be the option. 32 or 33 I think would work.
I use 32c Gatorskins on my Diverge. God they are tough old tyres, been over all sorts of sharp shale etc. with my 17st onboard. Zero punctures, slight buckle on front DT Swiss though!
november4
Is it rim brake? I moved from 28mm to 30mm totally fine, and run 60psi instead of 80psi.....huge difference, does light gravel ok. Need to open brake caliper to remove wheel
My frame max is 30mm, with the wheels I have
mirobertson
mirobertson
Regular
It’s a disc brake. I think the consensus seems to be to stick with 28s or maybe go with 30s but don’t bother going much larger since there isn’t much benefit and there is a risk of reducing tyre clearance.
Jameshow
Well I do much more road cycling and my old road bike was a bit rubbish. It was just a starter bike. Heavy with not great shifters. But I thought if I could repurpose the old bike it would be a bonus! The bike has disc brakes so thanks for the advice. Maybe finding a decent 33mm gravel tyre is the way to go. I suspect 35mm will be too wide.
Makes much more sense now!
I'd go for 32mm if possible you want 3mm clearance all round. Quite a few tyres come up small too.
