subaqua
What’s the point
- Leytonstone
In other words, break the law, who cares?!?
Front Lamp
One is required, showing a white light, positioned centrally or offside, up to 1500mm from the ground, aligned towards and visible from the front. If capable of emitting a steady light, it must be marked as conforming to BS6102/3 or an equivalent EC standard.
If capable of emitting only a flashing light, it must emit at least 4 candela.
Rear Lamp
One is required, to show a red light, positioned centrally or offside, between 350mm and 1500mm from the ground, at or near the rear, aligned towards and visible from behind. If capable of emitting a steady light it must be marked as conforming to BS3648, or BS6102/3, or an equivalent EC standard.
the CTC did an article on lights http://www.ctc.org.uk/cyclists-library/regulations/lighting-regulations
The Euro-friendly clause
Thanks to a European Directive of a few years ago, wherever a British Standard (BS) is referred to, equivalent standards from other EC countries must now also be recognised - but only if they provide an equivalent level of safety. It’s not exactly clear which do. However Germany has arguably the strictest cycle lighting laws in Europe so we consider it safe to use equipment that is marked accordingly, with a “K~number”.
It should also be noted that wherever a British Standard is referred to, that reference applies to a specific edition. In the case of BS6102/3, that is the 1986 edition, as amended on 15th April 1995 and again on 1st September 2003. These amendments (in conjunction with the 1994 amendment of RVLR) removed the filament bulb design restrictions, so that lamps may now get their light from LEDs, HIDs – or whatever comes next!
My Bold in the main body text
as others say bright lights and nobody will use it against you that they didn't meet BS blah blah blah
