GrasB
- Nr Cambridge
It doesn't quite work like that. I was far more likely to lock up or flip my self over the 'bars of my road bike than my hybrid because the harder I have to apply the brakes the less control I have over them.I am certainly not disputing the better control and modulation with disk brakes, this, along with instant braking rather than having to clean off the rims all help with reduced braking distances. No disputing that at all, in fact I stated that. I only referred to total braking power causing skids more easily on narrow tyres.
When calipers do bite, they can deliver enough power to lock the wheels and skid. I believe the same bike with fatter tyres will take more braking force before skidding on the same surface , that is all.
This of course is offset by the better modulation so can be controlled more easily with disks, but that wasn't my point. I have owned more than one disk braked bike, so I do appreciate that disks are the better solution.
Well you asked for it so don't blame me!... firstly that may be a simple question but the answer is certainly not simple. The short answer is: Yes, no, maybe & wrong metric!GrasB, you drive fast cars on a track right? Simple question: Would they drive\accelerate\stop as well with skinny tyres?
The long answer is: Put 250/515R13 slicks on a 'cento Sporting or old mini 1250GT/Cooper you'll never get enough energy into the tyres when hammer it around a track, net result is that a 160/515R13 slick will deliver substantially higher grip levels. Not only that but the lighter tyres (& wheels) will mean that you've got less flywheel effect in the wheel which means you'll accelerate & brake even faster. When I was racing my Cinq I was just about getting to the point where the 180/515R13 was faster than the 160/515R13, it was lighter than stock but had over twice the power & three times the torque.
When you get to treaded tyres it gets even more complicated, I ran a particular tyre with a 205/45R13 profile because that tyre offered the same surface contact area as their 185/50R13 but with much better water dispersion. Also getting the tyres up to temp was much easier on the 205s, because the blocks were further apart it allowed the blocks to move more & thus get temps into the tyre to get everything working properly. Moving onto road legal tyres best tyres were 195/40R14 sports contacts, they were better than the 195/45R13 or 175/50R13 sports contacts because they were a different softer(?) compound but of the R13 options the 175/50 was better for cold & wet weather grip but the 195/45s were better options when hot/dry conditions prevailed.
The same thing applies to the Exige, the rear drive wheels can go fairly wide (255s can be had) however for the front tyres going much over 205 wide causes problems with grip even with significant amounts of downforce.
