Road bike tyres losing small amount of pressure
I have the same bike, I don't know your weight but at 80kg, I find 90 rear and 80 front is plenty for that size of tyre. I should think 120 feels like the tyres are made of stone
I thought the same;don't have any tyres pumped up that high,maybe 93 max and that's on some 23's on old narrow rims.
The pressure written on the sidewalls is just the max a tyre can take usually;I'd give them a go at 85-90;less risk of pinch flats at lower pressures too(supposedly).
Surely it's the type of tubes you are using that dictate whether you get a slow pressure loss; not the tyres?
Don't think standard tubes should go down much in a day;latex ones always go down when not in use,they are lovely to ride on though,,,
e-rider
Banned member
South West
I try to ride everyday or failing that every other day & before each ride I always pump my tyres up , I've found that 120 psi works well for me , feels comfortable & the bike rolls well on that pressure
The reason that I ask though is every time I check them they're never still at 120 psi , more like 100-110 psi after say a 50/60 Mile ride , is this normal for tyres to loose a small amount of pressure after each ride ?
yes if the weather is hot - I lose about 5psi per day on a hot summers day. In the winter I lose about 5 psi per week
Globalti
Er... latex inners lose pressure at about 5-10 lbs a day. Even lightweight butyl loses some pressure. It's due to the air molecules passing though the molecular matrix of the rubber.
I weigh 76 kilos and I find the best pressure to be around 90 lbs. Above that my hands begin to tingle thanks to our crappy roads.
T4tomo
I can't envisage a mechanism where the type of tyre will affect pressure loss.
Me neither!
burndust
Parts unknown...baby
i have mine set at 100psi and pump to 105psi to allow for leakage when pump removed, top up every few days and always before and after a big ride, interestingly not a single puncture in about 2000 miles and i've been on some shitty roads
Tiny01
Tiny01
Darren on Bkool
Essex
I'd say you don't lose any air from the tyre when you remove the chuck. The valve gets forced open by the higher pressure in the pump. You stop pumping when the (wildly inaccurate) gauge gets to 100psi. The valve closes, but there's still air in the connector above atmospheric pressure. You take the chuck off and it's this air you can hear escaping.
Yep exactly that Tim & yes I'm just taking the reading from my Revolution track pump & yes I'd imagine that's not very accurate , are you able to advise me on a reasonable accurate tyre pressure gauge that I could then double check the pressures please ?
Tiny01
Tiny01
Darren on Bkool
Essex
I'm 99kg currently , if I tried to run on those pressures the bike would feel like I'm cycling through sand !
Feels comfortable with 120 psi reading taken from my track pump
