lulubel
- Malaga, Spain
I won't go on about how important it is that she gets her saddle to the correct height. I'll just say that I was terrified when I first did it, but I had to do it because I was suffering knee pain from too long riding with the saddle too low. It was much easier than I thought, and I have never fallen off because I couldn't get a foot on the ground quick enough. It's amazing how easy it is to "bounce" off the saddle if you need to get a foot on the ground right now, and your pedals aren't in the right place.
Regarding the brake levers, first of all, if the bars are too high for her, you can probably remedy this by moving the spacers from under the stem (there are probably at least two) to above it. (If you haven't done this before, google it because doing it wrong can damage the headset.
She shouldn't be having any problems with reach, I don't think. I've looked at the frame geometry, and the horizontal top tube measurement is shorter than I've seen on any frame I've looked at. I'm 5ft2, and the top tube on my road bike is 15mm longer. Moving the bars down will increase the reach, though.
Regarding the comments on bars and stem, the handlebars are already compact, and the stem is already short, so I doubt there's much you can change there. I've just changed bars on my bike and gone from a 75mm to 50mm stem, and I wouldn't recommend going that short with narrow bars, especially not for a road bike beginner. Let's say it makes the steering sensitive!
What you can do that might help is move the STI levers higher up on the bars, so the brake hoods are tilted back towards her more. This isn't considered correct, and it will make braking on the drops difficult at best, but if she isn't using the drops, that won't matter at the moment. This will push the brakes into her hands more. I can only get 2 fingers round the brakes when they are in their "correct" position. I can get my whole hand round them if I tilt them up.
For a woman with small hands, braking on the hoods is never easy, even if everything is set up correctly. I learnt very early in my road bike experience to always get on the drops when I was descending. On the hoods, I need to squeeze the levers as hard as I can to stop the bike. On the drops, on a dry road, I can lock the wheels with one finger on the brakes. So, your other option is cross levers, as other people have suggested, which won't give fantastic braking power, but will stop the bike in most situations. And if she thinks she'll need more braking power, she needs to get on the drops.
