I have posted this before, although I have updated recently so will list my ten pence worth below. Although it has grown to be quite extensive I have tried to put it all across in a plain and simple manner, they are my opinions based on over 30 years as a club cyclist and over 20 years as a specialist cycle retailer, as such I must add these are my personal opinions; I fully respect that others may have some different opinions to mine.
Frame material comparisons:
Frames made of Steel : Very durable (if built correctly) with low performance drop off with age. These days still a popular choice for club riders who like to know that their frame has been built in the traditional way by craftsmen. Production bikes built with steel are less common, although it remains popular with the companies that still cater for touring bikes.
Many cyclist like the fact that they are having something built often to their own specification, you can personalise your frame with your own braze on items, light bosses, extra bottle bosses etc, you can even chose your own colour. In the past all top quality frames were purchased this way, as it was how you got exactly what you wanted, both in quality and especially frame size. The old diamond shape frame being less adaptable in terms of variations in riding position than the modern sloping top tube frames; even Lance Armstrong used an off the peg frame size. Although I fall into this category, as in uses as steel frame, not Lance Armstrong, I have to admit that modern off the peg frames are now so good both in terms of production quality and the flexibility that the modern geometry gives you to achieve the perfect riding position, that the necessity to have a bike made to measure is less of an issue. In more recent years steel frames are starting to make something of a come back, as many realise that in many ways steel is a better option than aluminium alloy, especially when it comes to comfort.
Frames made of Aluminium Alloy: Often simply referred to as ‘Alloy’ Light, cheap, reasonably robust although some do comment that aluminium alloy frames are not as comfortable when compared to the others; in part this is why most will not use aluminium alloy forks, most current roads bikes will use steel or carbon. Aluminium Alloy supposedly has the most performance drop off, which in fairness only really effects a racing cyclist where a few percent reduction in performance can make the difference (especially in their heads) of winning or coming second, in reality that applies more to the older lighter frames when Pro’ riders used extremely light versions (now most pro teams use Carbon), the modern budget frames use a heavier, more robust alloy and are of course aimed at a different style of riding. They are now the most common option in the mid range and upwards frame sets, fairly robust, as they will normally dent as apposed to crack. Normally the price dictates a purchase of a frame built in alloy, that does not mean that you will not be satisfied, you will see quite a few older frames still being ridden by club cyclists who find them perfectly adequate, plus many don’t have any complaints re’ comfort or performance drop off. Although most refer to these frames in general terms as ‘alloy’ if we are being pedantic then strictly speaking this is wrong, as steel is an alloy of carbon and iron, titanium is normally aluminum and vanadium, for example Van Nicholas use 3% Aluminium, 2.5% Vanadium and 94.5 Titanium, which they simply list as 3/2.5
Frames made of Carbon:With sufficient research and development can result in a bike that is comfortable, very light and efficient at transferring energy into propulsion as the material does not flex as much as other materials. Although strong they can be more delicate, where other materials dent, Carbon is more likely to crack, although I don't believe that they are as delicate as many fear them to be, quite a few have been ridden for a few years now and still going strong.
Most common rider is a racing cyclist or someone who still likes to have a ‘best bike’ that can to an extent have a more precious existence than say audax or touring bike, where robustness may be more of a consideration. Most production high end ‘Race’ and ‘Sportive’ bikes will these days use carbon frames, we are also starting to see this technology filter down into the mid price range models.
Note my comment above stating “sufficient research and development ”, I would always recommend buying from a reputable manufacturer/designer. Back when steel was the material of choice, the best were built by craftsmen and the mass produced manufacturers did not offer the same quality of construction. With carbon frames arguably the opposite applies, the larger companies put huge efforts into research and development when designing their frames. Modern construction, if you have the facilities, which the major companies have access to, mean that they can offer a well designed, high quality product; low volume craftsmen struggle to compete on both quality and price. As such care is needed with budget carbon frames, they often are not that light, stiff, good to ride and more significantly in some cases even that safe to ride!
In recent years high end mountain bikes have also started to use Carbon frames, note they are not road bikes with different geometry, they are designed to be far more robust and impact resistant than road bikes for obvious reasons.
Frames made of Titanium : Until recently they were seen as expensive and rather exclusive, although they are starting to become very popular as the pricing now competes with many of the comparable alternatives. Virtually no performance drop as they don’t even rust, comfortable, light, yet robust. So much so that although I personally don't believe that anything does last forever; Titanium probably comes the closest.
Performance wise, a Titanium frame will not be as light or stiff as well designed carbon or now seldom used upmarket very light alloy frame, alloy when new that is, (note that as stated above most alloy frames are mid range only), although really it is that not far off. Until quite recently some pro racers used Titanium, like Magnus Backstedt, a former Paris Roubaix winner (2004), other Pro Teams used Titanium frames painted up to look like normal production bikes of their team sponsors, often used in races where comfort can become an issue, for example over the cobbles of the Paris Roubaix, as riders are bashed about so much it can lead to fatigue. However that in fairness applied more when Steel or alloy were more common place in the peleton, these days for those riders chasing grams and split seconds, most will chose carbon.
The down side is that Titanium is very hard to work/build with; so most manufacturers don't! On the upside because of this the workman ship simply has to be of top quality and it shows, most Titanium frames do look and are very well made. Most common used when someone wants a fast, responsive, light comfortable yet robust, durable bike and of course where price is not so much of an issue. Titanium is therefore and ideal choice for touring, longer day rides, audax and sportive bikes. Even though arguably they are a less valid choice for use as a race bike, they are still quite popular, as many do buy with a view to long term ownership, where not only robustness is a significant consideration but also style, many Titanium frames have very classic designs that should not date in quite the same way that the ‘bang up to date styles of the moment’ may do.
Frame material conclusion :, Opinion is often much divided when it comes to frame materials and if it effects how the bike rides or not. Many will state that they can tell a huge difference and by the same token many will state that the frame material makes no difference at all. I would say I fall somewhere between both, I have ridden a huge variety over the years, when riding bikes similar in set up in nearly every respect apart from the frame material I would say that I can't tell a huge difference, but I can feel more than none that's for sure, a slight difference it may be, yet significant enough to play a part in my decision making when choosing a new frame.
A quality designer and manufacturer will be sensitive to the material they have used, so I would expect the bike to perform how it is supposed to and give you good long service, regardless of what it is made of. So although the frame material is indeed a consideration I believe that many are far more concerned about what they should or shouldn't use than perhaps they need be.
Paul Smith
www.corridori.co.uk
