From the Found a Bargain thread - but you'll need to be quick !
You MAY use a light that flashes 1-4 times a second, but you do not have to. I don't unless I'm running out of battery because I want the less observant motorist to mistake me for a moped rather than recognise me as a squishy cyclist that will probably do them no harm if they cut me up.Am I not supposed to have a flashing light while cycling on the road?
It's probably still dazzling, which is illegal. Unless you fit a road-specific lens, it will probably need to be aimed less than 2m ahead of you to avoid dazzling other road users.I'm aware the light I have is pretty intense and point it towards the ground so that it isn't dazzling oncoming traffic or other drivers, so i'm not sure what I am doing wrong?
Axa Greenline or Cateye GVolt. Someone in the bargain thread linked a Smart 60 Lux which might be OK but I've not checked whether it's legal (StVZO most likely).Anyone any suggestions for a good cheap ish light for road use?
Hi, I'm commuting to work 2 days a week and have a hybrid bike. I'm using the following lights:
http://www.amazon.co.uk/dp/B00XMCJA9U
I have a fluorescent yellow jacket and backpack cover on so that I'm seen by as many people as possible as it's always been a concern of mine while cycling on the roads.
On the past two commutes I've been shouted abuse at by motorists. I'm not sure why on all occasions.
One comment was "That's illegal, unless your a copper" - I have no idea what he was talking about, I simply had my light on flashing as per usual, wasn't cutting in and out of traffic, and was sat waiting behind a car waiting for the traffic to move. This person was on the opposite side of the road coming towards me. I suspect he's just a mad man.
Then twice tonight coming home, I got abuse for having my bike light flashing, one woman shouting "I've got a F*cking headache, turn your light off" - again oncoming traffic, and a car I was overtaking while he was in traffic shouted "Turn off your flashing light, D*ckhead".
Am I not supposed to have a flashing light while cycling on the road? I'm aware the light I have is pretty intense and point it towards the ground so that it isn't dazzling oncoming traffic or other drivers, so i'm not sure what I am doing wrong?
Any advice would be appreciated. I might be doing nothing wrong and they may all just be mental where I live (Bradford, so it is possible!)
Ha ok, I don't need telling twice, I'll stop using it on the roads and certainly stop using the strobe mode. Anyone any suggestions for a good cheap ish light for road use?
Thanks all, I accept the abuse I've got on the roads and lesson learnt!
The problem is not the brightness itself.
Car headlights have a pattern that (when aligned properly) cut off the top of the beam to stop the light dazzling oncoming traffic
With the exception of a couple of German lights, the bicycle light is a full circular beam
This means that even when tilted down, there will be a bright forward beam
I note that your light also has lower power options.
Before ditching this light, try pointing it further down and using a lower power setting ... with the advantage of a longer battery life
@Hypermind, I've got Tha light and use it on roads, mainly country lanes where I am so I need to be able to see, but it definitely needs to be pointing down, I actually twist it down on the handlebar mount when a car is approaching ( my version of dipped beam) when I first started using it I too was dazzling people, but like you they soon let me know via the medium of abuse and general nobberishness. I don't think mine has a flashing mode or if it does I don't know how to select it
Why? It's dearer than the Smart (£17 instead of £9), less bright (15 lux v 60), I can't tell if the battery is replaceable (Li-Ion v AAs), looks like less side illumination. The only thing it might be better on is battery life on constant, claiming 9h instead of 6h. Can't help some people.I think I'm going to buy this light for the meantime, (money is tight at the moment):
https://www.radialcycles.co.uk/radial-pharos-3-watt-usb-rechargeable-front-light.html
The Volts have a rubbishy torch beam, don't they? The GVolt has similar good points, plus a decent beam, although the naming changes from random lumen numbers to lux.as for lights - Cateye Volt 300 front and 50 rear. solid, robust, reliable, good battery life and excellent long term VFM, also nice and compact for carrying around off the bike
Sadly, there is no lumens measurement method specified in the British StandardsYou don't need to spend money on new lights as pointed out earlier in the thread and the amount of lumens claimed for your light is BS.
Which means you're going to be riding into the brightest spot in half a second at 10mph, doesn't it? That's why such O-shaped beams are pretty rubbish for seeing where you're going compared to shaped beams.it's fine for the road as long as you have it on low or medium and make sure it's really angled down so the brightest spot is hitting the road 6-8 feet in front of you.
