Update
Well I have dropped 20psi and its certainly a lot better than it was. Still a very harsh ride though, and despite the back ache I still prefer the ride to that of the
Ribble frame that it replaced.
While it has to be said the Ribble frame is good value for money, it is very wooden feeling, especially when you were trying to get a move on.
But I also encountered another "problem". I noticed the other day that I was tending to rid leaning over to one side? Hard to describe, but when I was riding and looking at the front axle, instead of seeing a tyre in the central with uniform amount of spokes visable either side, I noticed that I was looking at more of the right side of the wheel?
Its very hard to describe, but the bottom line was that the bike was NOT at 90 degrees to the road when I was riding??
So armed with a tape and a long spirit level I set about establishing what was causing me to lean over? I dont do it on any of my other bikes, so why this one???
Well after lots of measuring and plenty of head scratching the answer was that the left hand brake lever was 15mm lower then the right hand side.
I can see how it happened, when I fitted them, I measured from the floor to the lowest tip of the levers. But when I placed a spirit level on top of the hoods, they were on the piss.
But you would think that it would cause me to lean the other way would not you?
The good news was that I managed to move it up without to much disturbance to the bar tape.
So I am now back riding at 90 degrees to the horizontal again.
