numbnuts
- Gone over the hill and far away
I always ride on the hoods and the bendy bits is there to hold my bar end shifters
Maz said:Numpty question: Do you normally hold the tops (hoods? i.e. the flat straight bit!) when indicating?
danny121 said:Just a silly question, but I see a lot of references on various forums about people spending most of their time on the hoods.
I spend about 80-90% of my time on the drops and only switch to hoods if I need to change hand position or when going uphill (seems to help).
Is there some reason to stay on the hoods I'm not aware of?
fossyant said:Ususally hold the brake hoods when indicating as you can brake as well !
bobg said:Just as a matter of interest, do many of you chaps set the bars with the "ends" - ( the final bits of the drop ) - horizontal, and the brake levers set to allow for easy braking from the drop position ? I'm told that's "correct - if there is such a thing as "correct " on bike set up, but I find that if I do that the the hoods are too far down the curve of the bars to ride on?
Chris James said:The setup you describe is pretty old school! Modern pros seem to kick their hoods up a bit, and you see some recreational cyclists with the bars tilted WAY up, so much so they have no chance of operating their brakes from the drops.
Me, I tilt the end of the bars to face slightly down (towards my rear brakes?), I can operate the brakes from the drops comfortablly with a couple of fingers but it makes cycling on the hoods (and particularly uphill) more comfy.
Like most of the posters here, I spend the vast majority of my time on the hoods. Only going on the drops for max speed or for long downhills.
Smeggers said:Im 95% on the hoods. Any time on the drops really hurts.
Depends on geometry I suppose.
