Beebo
Firm and Fruity
- Hexleybeef
yep, they've closed it, for bikes only, before 7am.Ride through the Blackwall tunnel?
RICE asap (and ibuprofen)
Read this, it will show you where the official drop off points are. From Stockwell you should aim for the drop offs at Jamaica Road or Blackwall lane.My plan is to get a mini cab to Greenwich area (or as near to the blackwall tunnel as possible) and ride through the Blackwall tunnel before the 7am closure.
NB: I'm coming from the Stockwell area
I've now brought a lock but I'll probably have it at the start before putting it in my bag that's going to the finish to use at the secure bike park to make it a bit more secure.
Just one (possibly daft) question, those with locks, will you be locking your bike to use a portaloo and if so, where will you lock it to or is it just more as a deterrent?
Depends what's causing it...overuse? Then the R bit is key hereWell, I've got the ibuprofen part down...
I think you're right about the RICE suggestion. Hoping it will just go away might not be the best strategy!
Depends what's causing it...overuse? Then the R bit is key here![]()
Worth getting out of bed early just for that. If then the weather were bad and the organisers were to allow someone to take a no show place, that would be even better.
I'll probably just have a long cable lock and a padlock to stick through the disk (ala a motorbike disk lock). I'll lock it to something if I can, but even just immobilising it will be a start. Again it's playing the odds, I think someone is a lot less likely to walk off with a bike that can't roll a wheel, they'll just nab the unlocked one next to it.
Take an allen key and slacken off the bolts in the stem. Then if they do nick it they'll fall off immediately. It may be a bit of a faff getting it roadworthy again, mind.(Warning:Not an entirely serious suggestion)
Edit. I'm off to kickstarter with my idea for exploding stem bolts. A motion sensor will start a countdown and, unless you enter a secret code, all the stem bolts will explode. And possibly the pedals too.
If you remember yourself that you have loosened them and don't fall off yourselfTake an allen key and slacken off the bolts in the stem. Then if they do nick it they'll fall off immediately. It may be a bit of a faff getting it roadworthy again, mind.![]()
About feckin time n'all! That's where I had a blow out last year!Forgot to mention that I saw a tweet yesterday or the day before where someone said that they saw Surrey County Council filling in the pot holes around Leigh Hill.
