Domus
- Sunny Radcliffe
Let’s hope we do better than Patrick McGoohan and find our way out.
Well, he did in the end...Let’s hope we do better than Patrick McGoohan and find our way out.
The train should get into Clitheroe just before 10:00 so if it is on time, we'll leave at 10:00. We intend to go via Paythorne Moor, which will slow us down a bit, so I think the earliest we would get to Rathmell would be 11:15 and it could be nearer 11:30. Aim to get there, say, 11:20-11:25 to minimise your loitering? If there is any significant delay (due to trains, punctures, llama attacks, whatever ...) I'll text an update to you.Now that you presumably know some train times, what time will you be leaving Clitheroe, Colin? I'm still aiming to loiter in Rathmell, on the bench outside the reading room, so an estimate of how long you'll take to get there would be good too. I was previously imagining that you'd be there in the region of 1115? And do you know what time Carrie and Kevin get in to Settle station?
You sell it well!Have popped in that church at rathmell on a ride. Have an idea that it was nice or interesting in some way but can't for the life of me remember why.
I would probably forget, so I have set an alarm to remind me at the station! I assume that your number is still ***** *** 745?This is all most civilised at my end then. Rathmell's only about 45-50 minutes so I can leave at 1030 :-) I'll check for messages before I leave and would appreciate a 'leaving Clitheroe now' text, but I won't be bringing the phone, so if you don't turn up I'll just assume that you've all become the latest victims of the Wigglesworth llama flock.
The phone alarm is set to go off just after the train is due in, by which time I should know what is going on so I'll text you either to say that we are setting off, or to report any delay!Correct re number. Don't worry if you forget. I'll set off anyway.
They are going via Airton, but I don't know how they are getting there. You are right that if they don't do those horrid valley A-roads then the alternatives are probably pretty lumpy!EDIT: Bingley! That's a solid 50km from Settle by a relatively direct route that isn't actually the A65 and A629. Quite a bump-up in non-wimpishness there.
