Rhythmic clank-clank-clank when rear brake applied...
Mazz
Leicester
On way home last night, I applied the rear brake while approaching a red light and I noticed a rhythmic clank-clank-clank coming from rear wheel.
First thought was that the old rim had a split in it & the split was hitting the rubber brake shoe. When I stopped to look, it wasn't that, I couldn't see anything wrong, so rode on. Applied the brake again - same noise, clank-clank-clank.
When I got home, I noticed there was a lot of lateral play in the caliper "jaws" (in direction of yellow arrow, see pic)...if I held the brake adjuster cam between finger and thumb it would wiggle about 5mm.
I (rightly or wrongly) tightened up the hex on the opposite side (red arrow), thinking this would fix it, but same thing happened again this morning.
Any idea how to fix this problem? Thanks
T4tomo
It might be a slightly buckled rim
Mazz
Mazz
Leicester
As there is lateral movement, is the retaining bolt that holds the mudguard and caliper assembly loose? Check the rim again for any links.
You mean the bolt that's sort of around the back (green arrow)? I'll check it later.
Mudguard is only held on by tie-wraps btw.
Mazz
Mazz
Leicester
I spun the back wheel and watched the gap between brake shoe and rim. The gap was cyclically going big then small, so I think wheel must be mishapen.
That bolt was tight, not loose.
I checked wear on the rim. There's plenty of ridges on there then I noticed it's starting to split, so I need to replace it. At least I know I've got my money's worth out of it.
I will replace the rear wheel and see if I still get the noise problem.
Thanks all.
Paulus
Barnet,
I spun the back wheel and watched the gap between brake shoe and rim. The gap was cyclically going big then small, so I think wheel must be mishappen.
Thanks all.
That would seem to be the cause.
Ming the Merciless
There is no mercy
Inside my skull
You should periodically measure rim thickness and also use a straight ruler to check for concavity. Essential for rim brakes. Not a problem with disc brakes. I used to go through rims once every two years in my rim brake days.
Mazz
Mazz
Leicester
Good advice.
This wheel's lasted me nearly 7 years of daily use, so I can't complain.
  • Like
Reactions: C R
Gone through a rear in 12 months on my commuter - back wheel does get covered in grit though (washed after every wet commute). @Maz, that wheel is worn out, hence the split appearing at the rim joint. They go with a big bang (I've done it).
