confusedcyclist
I'm rebuilding my rear wheel with a 11 speed compatible hub.
This is my first time dismantling a previous build that's been in use for a while. The spoke threads have gunked up a bit as they were oiled during the initial build. So I cleaned the spokes down with a bit of WD-40 and wiped them off with a clean rag. The nipple threads are a bit trickier to clean out, but I painstakingly squirted the inside of all 36 nipples with the straw applicator on the WD-40 canister. When threading the nipples back on the spokes there's some grinding from contamination of the majority of the nipple threads.
Does anyone have any tips on how to clean these out a bit better for reuse? I want to avoid a special trip to buy new nipples, if I can just clean my existing batch, that would be great. Aside from one or two which were rounded, most of them are in great shape (contaminated threads aside!). I have quite a few spares left over from my previous builds, but not enough to replace all the contaminated nipples.
