andy45zulu
Hi
im having problems setting up my front derailleur. i ave set the height and ngle. i have then gone into the small chain ring to reset limiter screw. the problem arises as i cannot shift into the big ring to reset the high limiter screw the cable is tight but there is no movement in the derailleur at all when i try to shift...thanks in advance
