replacing a chipped sprocket on a hyperglide casette?
bobg
The chain's been slipping on the 15 tooth sprocket of my fairly new hyperglide cassette and I've just discovered a 45 degree biggish chip out of one of the teeth. I'm guessing thats the cause cos the chains new and all the other gears run silky smooth. Rather than fork out £25 for new 21-11 can I buy a replacement 15? No luck so far via google. Failing that I wondered if I could get away with a unramped one designed for a single speed convesion or would i make indexing significantly "graunchy" Apologies for bein a cheapskate, its in the blood!
domtyler
If it's new then take it back and tell them it was defective.
If you can find a UG sprocket on it's own then you might get away with it - take it back or buy another cassette - no option these days !
bobg
bobg
Steve Austin said:
If the shop won't change it will work fine without that tooth
Steve, That suggests that it might not be the chip thats causing the chain to slip? Or do you mean file it down so the chain doent bear on the chipped bit
BTW , when I said "quite new" I may have exaggerated just a tad:blush: ie not new enough to take it back... I believe I was a litle heavy handed with the chain whip, ie I needed a 3 ft bit of scaffold pole to get it off ... which slipped a little just a few times :ohmy:
bobg
bobg
Aw, to hell with expense , I'll throw caution to the wind and buy a new one:biggrin: I will of course be inconsolable if it still slips.... ( or is that unconsolable)
Chris James
Huddersfield
Without going to look at my own cassette, I understood that Hyperglide cassettes have missing bits of teeth to help shifting.
Do the other teeth look like shark fins? If they look okay then I doubt this tooth is your problem.
Steve Austin
The Marmalade Kid
Mlehworld
yep. remove that one tooth with some pliers/a saw. it will work well enough to get the use out of it. it will still be engaged with more teeth than when on the 11 tooth cog.
andrew_s
Gloucester
Agreed.
It's sticking out bits where the tooth is twisted or something that cause problems. One missing tooth is nothing.
Here's my worst ever sprocket, with 10 teeth gone.
bobg
bobg
Chris, None of the teeth look like this one But if I'm honest if it hadnt have been that the LBS suggested it I'd have thought it wouldnt have made any difference to its operation -It only slips under pressure and the chain doesnt move from the 15 sprocket or ride up, it just well... slips! Neither they or I can think of another option! I'll file it off Steve, just to see if it does the trick I think, then get a single sprocket from SJS as per Uncle's link and Lee's pm. Mind you a full 105 cassette from Chain Reactions is 16.99 ( 50% off ) and it cost me more than that today to take my son to the pub for a pint and a pie :rolleyes:
Thanks to all
bobg
bobg
andrew_s said:
Agreed.
Bloody Hell Andrew... moths??:rolleyes:
bobg
bobg
Just for the sake of general interest... I ground off the offending tooth but the chain's still slipping. Just ordered a new complete cassette... if it still slips I'll be back for further enlightenment
