Replacement left hand crank
nick_a_louse
Hi all,
I took the quiet roads as a good excuse to start cycling again (after a year long hiatus). Did a quick service and everything seemed alright, but after about 20 minutes on the road, my left crank started coming loose. Unfortunately I didn't have any tools, so it was a slow trip back with a wobbly crank (hand tightening every so often).
In my naivete, I thought it was just a case of tightening up the allen bolt and away we go. Sadly, it started to wobble after another half an hour and having taken it off, I can see that the corners are now slightly deformed and it needs replacement (the shaft of the bottom bracket looks ok).
So, I need a new crank, but there doesn't seem to be a reasonably priced replacement around. Specs are:
- 175mm length (centre of hole to centre of hole)
- Black
- Diamond hole
- Alloy
- Off a Specialised Sirus
Anyone able to suggest a replacement part that is actually in stock, or am I going to have to get a full crankset?
Sharky
Kent
Make sure you haven't left any debris in the crank. I did once and the crank kept coming loose. Once cleaned, the crank bolts tightened up properly.
For a lh crank try sjs cycles
faster
If it's not too damaged, I've had luck before by giving everything a really good clean, applying red loctite to the taper and threads then doing it up nice and tight.
Obviously, not so much you snap the bolt! Once set, don't re-tighten or it'll break the bond of the thread lock.
N
nick_a_louse
Thanks, I'll have a look when it's stopped raining, but I suspect the damage is done (a couple of flakes were in the grease that got on my hand).
Had a look at SJS, but no left hand 175mm cranks on their own (so hopefully someone else can throw a suggestion my way)
rivers
How far can I go?
Bristol
Make sure you use a torque wrench to tighten it to the correct specs as well. And don't lose the little piece of plastic that sits in between the bolts.
N
nick_a_louse
Potentially stupid question, but are the Shimano Alivio octalink connections to accommodate both square and diamond fittings, or it's a proprietary fitting? I assumed they were for some sort of spline (as the descriptions never explain this). Otherwise, the only diamond fitting I can find on the SJS page is silver (which would look a bit weird since everything else is black). Can't see any 175mm diamond fitting cranks on Halfords.
Unless I'm missing something....
N
nick_a_louse
Haven't found an online manual for my bike yet. Is there an approximate recommended value?
Edit: I think it's supposed to be 34.5Nm
Overconfidentii Vulgaris
No I don't think you are missing something. Octalink is a splined fitting so not compatible with what you have.
I did think of Spa cycles, who do have black left-hand cranks with the right hole orientation but only in 165 or 170mm.:sad:
You may end up having to buy a complete chainset. This one at £20 is no more expensive than some of the arms on their own, has the right orientation of hole and the right arm length: https://www.decathlon.co.uk/bike-triplebottombracket-789-id_968556.html
IaninSheffield
Sheffield, UK
My fault, sorry. Defer to @Rickshaw Phil
I’m a bit confused, by ‘diamond hole’ i assume you mean square taper, in which case the chainset linked by Rickshaw Phil would be a good choice. Don’t be tempted to buy a Octalink chainset.
Square taper comes in two orientations. Square like this Thorn crank: https://www.sjscycles.co.uk/cranks/150-thorn-left-hand-crank-arm-black/ and diamond like the one I linked to: https://www.decathlon.co.uk/bike-triplebottombracket-789-id_968556.html
Get the wrong one and you get cranks at funny angles.
