I like Skol
A Minging Manc...
- Sunny Ashton-under-Lyne
Put loose bearings in like I said up thread. The more bearings the better to reduce the pressure on individual bearings. The bearings are only put in a cage (the ring that holds them in a circle) to make bike assembly super quick but you can take the time to put the individual balls in place. Just make sure not to cram too many in because this will cause them to bind and destroy things pretty quickly. When you have the right amount in place there will be a small gap, less than the size of one bearing, between the last bearing placed and this allows the bearings to roll.
