Spinney
Bimbleur extraordinaire
- Back up north
Yep, Fire doors, protected routes of escape and plasterwork(lathe work) not being good enough is often the issue.Our current renovation requires correct staircase gradient and headroom, fire doors and exit routes.
As previously said, That was how we spotted the issue. The access to the garage was a normal internal door not a fire rated one, was a stud wall not a concentrate wall and not a stepped access to stop liquid spreading.Our current renovation requires correct staircase gradient and headroom, fire doors and exit routes.
Sign off was done by a private firm, but the letter also had the local council's details on it, so I assumed it was an approved contractor or some such thing.
I accept that standards might change - I bought in 2014, and the house had just been renovated. It's things like whether the loft should be ventilated (I assume yes, the buyer's surveyor said it wasn't but he only stuck his head through the hatch, and I wanted to know if that kind of thing was required in 2014 and if it was checked).
Also, there is a solid fuel stove, but I never got a HETAS certificate for it, which buyers seem to want. I don't know why my conveyancer did not ask for this when I bought the house, but I wondered if the installation was covered as part of building regs. I don't think either would be very expensive to sort out/get, but I did wonder if they were things that should have been checked when the place was signed off.
Any Completion Certificate issued by an Approved Inspector is valid though you can challenge the Approved Inspector's findings and the contractor's work if it's defective. Contracts for defecrtive work can be challenged for up to 6 years from the work being completed for contracts signed under hand. Legally you have no contractual link with the contractor or the approved inspector who did the work for the original owner and it might only serve to identify any shortfalls which you would then be responsible for.
It's impossible for anyone to say for certain without seeing the drawings, the specification and the work done- I'd speak to your local Building Inspector for peace of mind.
Thanks for that info - I realise they have no contractual link to me, I was really just after information.Any Completion Certificate issued by an Approved Inspector is valid though you can challenge the Approved Inspector's findings and the contractor's work if it's defective. Contracts for defecrtive work can be challenged for up to 6 years from the work being completed for contracts signed under hand. Legally you have no contractual link with the contractor or the approved inspector who did the work for the original owner and it might only serve to identify any shortfalls which you would then be responsible for.
Thank you.Loft spaces can be sealed warm roofs or vented cold roofs [depends where the insulation is].
Can be ventilated with either, 10mm continuous slots at eaves and 5mm continuous slots at ridge [or equivalent, or have breathable roofing membranes [Tyvek or similar, usually printed in large lettering on membrane itself!] which don't need vent slots at eaves.
Wood burners need external ventilation under Building Regs [usually an air brick or possibly through floor if suspended floor], it may rely on vents in windows or under doors for combustion air supply, or it may be a sealed balanced flue fire.
Lots of variables, best speak to B Inspector for complete peace of mind- you may need to do retro work if needed under B Regs but then that's for your safety and acts as a paper trail if you sell on.
