+1 Breaking the bond is the key.First make sure you are turning in the right direction then give the end of the spanner a light tap with a hammer.
You are just testing us, aren't you - that tightens up the pedals!how does it go... pedals vertical, foot on the lower pedal, spanner on high pedal, pointing towards rear of bike, pull up on spanner, keep bike on floor using pressure from foot on the lower pedal (you should be leaning over the bike). Doesn't matter which pedal you're undoing this way... but you might benefit from a longer spanner.
yes you're right... spanner pointing towards FRONT of bike to undo... doesn't matter which pedal you're undoing though.You are just testing us, aren't you - that tightens up the pedals!
I remember it as the right side pedal having the 'right' thread (tightens clockwise, as usual) and the left side has the 'wrong' thread (tightens anticlockwise).
I was always taught to pull a spanner rather than push it... to save knuckles![]()
