Night Train
Maker of Things
- Greater Manchester
How can I remove aluminium cranks from a steel bottom bracket shaft when it is feels well and truely welded together?
I have tried bashing it with No1 bike tuning tool (big lump hammer), using a gear puller (bent chain rings into a taco), gear puller and No1 bike tuning tool (loads of noise, no movement).
Both bits are scrap anyway but I want the frame member for mocking up, preferably with a bottom bracket still in it. The frame is aluminium too.
Thank you.
Thank you.
- extreme talents
) I couldn't bring myself to do that
). The old crankset was put on by the LBS (due to faulty BB bearing) when the bike was only six weeks old, nine years ago. I've never done a cotterless crank job before (but I've seen plenty done at the LBS when 'passing the time of day with the lads'), so I had a new crankset, new BB bearing and new crank extractor tool. Took the plastic bolt covers off ... No (or hardly any) sound thread to see in there. Gave it a try ... the extractor bolt simply pushed itself back out. Bike on its side (with block of wood under opposite crank for support), hacksaw down as far as the bearing shaft, drill a series of small holes from there to the edge of the crank. Sharp stone chisel and lump hammer, two or three good taps ... Called in the LBS a couple of days later and told the manager (the only original member of staff) ... My how we laughed
