EasyPeez
- Cottingham, East Yorkshire
Ace. I was trying to feed the chain up through the jockey wheels instead of down! Figured I'd need the chain ends to meet above the chainstays/coming out of the top of the sprocket in order to be able to join the ends effectively, but I guess there's no reason why I can't join the chain as it runs under rather than over.Pull a full 50% of the chain through the cage plate and then grasping both ends lift it up to clear the chainring teeth.
Shift the front derailleur into the smallest chainring position and then lay the chain upon it. Allowing the right side (frontward) tail to hang off the front of the chain ring under its own weight...
... thread the left (rearward) tail over the smallest sprocket, through the top of the rear mech and threaded onto to the jockey wheels.
Things like this come easy to some people, not to me!
Thanks for your help
