Drago
- Suburban Poshshire
I use a big old car ball joint splitter.
How hard was the drilling? Did you use a regular (handheld) drill? (I'm not investing in a press - this is a one-off on an old bike...I don't plan to make a habit of living with cotter pins.)
Heat applied how? Would a hair-drier do? (Serious question.)
Thanks. 'cept if you don't have one, eh?Hot air gun better than a hairdryer.
You could try it might take a while and be a lot gentler than you needThanks. 'cept if you don't have one, eh?
As for blowtorches, me & the blowtorch have never been introduced, and I have a feeling it's probably best to keep it that way.
A little creme brulee butane torch is easy to use heating the pedal alone rather than the pedal, the crank, the axle and burning all the paint off the bottom bracket with a proper plumber's blowlamp. I would always use heat to assist the techniques below and add penetrating fluid to the hot parts. Buy the torch; there will be other stuck nuts/bolts in your future.
I bought new cotters for my 1949 MG kingpins; was puzzled that they had threads on BOTH ends, the tapping-in end fitted with a domed nut (see pic).
I think the genius idea is you can just removed the domed nut, add a stack of big washers and then tighten the domed nut back to draw the cotter pin back out; so the cotter pin had its own built in cotter-pin extractor.
I shall use this principle next time I get a stuck cycle cotter; I'll drill the cotter (hammering-end NOT threaded end) part way using (say) a 4.2mm drill which is correct to tap an M5 thread inside the cotter. I can then pop the stack of washers, or a socket/pipe-offcut and a washer over and draw the pin out with an M5 bolt. I suggest M5 assuming a 1/4" (~6mm) cotter. A set of 3 M5 taps is about £5.
All hammering on the cotter pin's original threaded end tends to swell the pin and make it stick harder. My favourite technique in the past has been to drill a hole and then drift the cotter-pin out with a parallel pin punch in the drilling; I file the end of the damaged cotter threads flat to allow me to, very carefully dot-punch the exact centre then drill a good long way through the pin, usually drilling about 4.5mm to take a 4mm pin-punch. With care a 4.5mm drill in a 6mm cotter-pin shouldn't wander and damage the pedal-crank. The drilling heat will help release the pin, the 4.5mm hole will allow the metal of the pin to relax a little away from the crank and, if you drilled the cotter right through the axle, the pin punch impacts will be PULLING the taper part of the pin through allowing it to shrink, rather than swell and jam more. I have tried using a cut-off nail as the pin punch; crap! Get a cheap pin punch.
- and you've just resurrected a 5 year old thread
Great post! If the Welsh language can be resurrected, so can cottered cranks.If only they could do that for youthful health and fitness!If the Welsh language can be resurrected, so can cottered cranks.
Heat could be the only way I'm afraid however be careful as the grease in the bottom bracket will be no good after excessive heat. Local heat on the crank then clout the pin.
