Removing a stuck lock ring
Sheffield_Tiger
I find the best way to deal with these is to find someone with an impact gun, the type used by tyre fitters etc. It is a shame you are not closer as I would happily remove it for you.
Will have to try that next time I get a tough one, I have an impact gun from my days towbar fitting, never thought of taking it near a bike. Now I think about it, would be good for using the M16 Bolt & locknuts method of removing old-style b/b fixed cups
screenman
I must be honest and say that I was shown the trick by a very skilled bike mechanic and frame builder, Barron Cycles for anyone near Lincoln. I had one that was refusing to budge using all the normal and some paranormal methods, so he did it in a few seconds. Bit embarrassing seeing as I have a mechanical background along with compressor and gun here in the garage.
Part of the problem is that the lockring binds with the small sprocket.
One "last resort" trick is to hacksaw carefully through a spacer - taking care not to go through and cut into the freehub.
Once removed that last sprocket can be pushed away from the lockring and stops it contributing to the resistance
Yellow Fang
Yellow Fang
Reading
I took the wheel into engineering workshop at the university and tried to loosen the lock ring by putting the bit in a vice and turning the wheel. Using the skewer to hold the bit in place, so it did not jump out, was a good idea. However, I still could not turn it. I got one of the technicians on the job and he couldn't turn it neither. He tried sawing the lock ring with a hack saw and it just slid over. Then I got him to use an angle grinder on it. Eventually he got it off, although he had to angle grind away virtually all the lock ring first. There is a little bit of wear on the spindle, but I don't think it is important. The hub is undamaged.
Cyclopathic
Leicester.
Good news. I am especially pleased that it was the angle grinder idea that did it. :smile:
StuUngar
Hilarious - had the same problem on a bike I bought at auction. Tried some penetrating oil, hammers - absolutely locked tight. I knew that the only way I'd be able to get it was with a vice - it was like it had been welded in there!
I didn't bother in the end as I would have had to spend out on a vice & then mount it very securely. Quite surprised that your LBS couldn't do it though. I'd have thought a strong well secured vice would be a necessity if repairing bikes professionally?
02GF74
the only thing that is stopping the tool going further in is the spacer/nut on the axle.
if you can get a socket onto the nut cassette side, then undo the nuts on the non-drive side, you should be able to remove the axle. Reapply the lockring tool and job done.
By the way, there are different variants of the lock ring tool - the two I have differ by the diameter of the inner recess - I have found that Shimano tool, which also has a central rod that goes into the hollow axle is the best.
