02GF74
you need to keep the drill steady or else you end up with a snapped bit in the bolt which is even harder to drill...... so to answer your question, no, a hand operated drill will not work.
re: seat post clamp - can you get junior hacksaw blade or a dremel cutoff disc in the gap? even if it means a bit of damage to the clamp - it will be cosmetic, it will allow you to remove the seatpost and the clamp; then you can use a drill press with the clamp in a vice to drill out the bolt.
for the steerer, that will be 6 mm bolt so you are bese using a 6 mm drill to drill off the head -you will then hammer the start fangle washer out through the steerer and if money is tight, again use drill press to remove the bolt.
beware of cheap extractors - they have a tendancy to snap making the job more difficult.
and went to a bike shop, IIRC they had allen keys in half sizes and managed to get a 4.5mm in what originally was a 4mm hex bolt.
