So 0
As the night closes in sooner every passing day, the leaves are falling and the freaky night cyclists emerge from the depths (me included!)...
What are the current thoughts on reflective clothing?
Based on a lot of evidence, studies and other people's viewpoints I am inclined to believe the following...
- Yellow High Viz is so overused these days that people are basically mentally blanking it out
- From riding motorcycles and cycles for many years I am of the opinion that you could be wearing a full size Mr Blobby outfit, and if they ain't gonna see you, they ain't gonna see you.
- Movement reflectives (Pedals / leg bands) may help the issue
- ProVis is excellent but like riding in a binbag in terms of sweating
- Lights lights lights (I ride with lights even in the daytime as they are hard wired in anyway)
Now I will sit back and wait for you all to tell me how wrong I am
I will always wear a helmet - never mind other traffic, I can make a mistake myself leading to a body/ground interface.The one I fail completely to understand is long distance cycle routes, 90% traffic free and still the helmet, hi viz, lights gubbins?
I second that, only time I needed an helmet was on forest lane(gravel covered tarmac) with no traffic ever. Digging thumb size stones from helmet was quite a shocker for my ridemates...I will always wear a helmet - never mind other traffic, I can make a mistake myself leading to a body/ground interface.
And if it is at all dull, and there will be ANY traffic on my route, then at least a (flashing) rear light.
A set up so good you rode all the way to the funeral director to purchase a pre-paid funeral plan...View attachment 610476
I like lights, 2 front, 2 rear plus flashing bar ends if needed too. And additional reflective tape on both mud flaps.
I do like the fully reflective jackets too, can’t remember the name of the one Mrs SnG has….
I think the more the better, especially on dark country lanes….
After, anything that can attract attention raises the possibility that a driver might see you.
Lights don’t have to be dazzling… just there….
Decent is subjective. My rear light I would say is decent. Nearly thirty years old and slightly knackered, but still decent enough.If you ride without decent lights, then you cannot have ridden anywhere with traffic. Otherwise you would forcibly be no longer be riding.
They are orders of magnitude more important than reflectors.
Big bright flashers, if anything, are indecent. But then most of my night time riding is commuting in a built up area, with streetlights, so lights aren't really necessary.
Decent mean bright enough to be seen, given the prevailing conditions.Decent is subjective. My rear light I would say is decent. Nearly thirty years old and slightly knackered, but still decent enough.
Legally, you no longer need to have a steady light. That law was changed quite a few years ago.I generally wear either a hi-vis coat/vest or a colourful t-shirt when riding
First sign of any reduction in in light and I put on 2 front lights and 2 rear lights
in both cases one flashing and one steady
I read somewhere that people have problems judging distance from flashing lights and that is why legally you should have a steady light.
If it gets dark I have 2 more lights at each end if I need them. One of the front lights is quite bright so is only used on dark paths or when pointed quite low - away from the sight line of any cars so as to avoid dazzling them
No idea if it works - but it seems better than nothing
However, it is naff all use of the driver doesn;t look which is where defensive driving/riding helps out. I assume no-one will deliberately drive into me (I'm an optimist!!!) and if I'm directly in their path with a light pointed right at them then they will see me (see - more optimism!)
Before winter I aim to get a light for my helmet (which is bright white) and some reflective tape for my mudguards
AT the very least - when I get run over and someone says SMIDSY I want to be able to point out as many things as possible!
Of course - we shouldn;t have to - but there you are
If we're talking legal requirements then of course that includes rear red and pedal reflectors although tbf I'm not sure that any of the lights I own are technically legal as I don't think they're BS marked (or equivalent whatever).Decent mean bright enough to be seen, given the prevailing conditions.
A rear light (ideally flashing) is MORE necessary in areas with street lights than on unlit roads (though legally required after dark on all roads). A front light that actually lights up the road, however, is only needed on unlit roads or trails.
Flashing lights don't need to be stupidly bright, it is the flash that attracts attention.
