well today the last of the bits i had on order for MK2 has arrived iv now just got to prepare cut and weld it all together
iv not got much done so far just a few little bits of cleaning up and stuff i have made a duel brake leaver here are some pics
the leaver and a plastic thinggy you find on the guide ropes on tents
slot cut out for the plastic thinggy
plastic thinggy inserted
2nd plastic thinggy with the 2 outer holes drilled out and taped to take cable adjusters
here is the completed duel control for the front brakes the 2 plastic thinggys are secured with self tapping screws and of course the tension of the cables,
iv not tested it out yet as iv not built the trike lol, but i cant foresee any problems with it the 2 plastic thinggys from tent guide ropes are very tough and dont have any real flex so i dont see a problem with them but just in case iv also made 2 metal ones for if i need them. but i think the plastic looks better as it matches the brake leaver quite well.
iv also started work on a leaver for the rear brake that will lock on at the push of a button but if you pull the leaver it unlocks automatic, so there shouldn't be any risk of locking it on as im riding. im trying to find the right stiffness spring. i started off with quite a stiff spring and 6mm bar but it was to bulky so im now playing about with an old cheap tent peg (the type that bends when you use it ) and the spring out of a pen and it seems to be working quite well im just having to fine tune it so it looks and works well.
the other thing i have made is a couple of jigs to hold the front wheels. on my first build the biggest problem i had was trying to hold things in place with clamps and by hand and weld with one hand and its not easy i can tell you i ended up sitting with one leg wrapped around the front wheel while the other had the frame balanced on the knee and still trying to hold the angel finder and make sure everything was in line. not easy i can tell you many a blue word was said
so a couple of bits of 2x2 screwed together with a 14mm hole drilled threw at the hight of the axle on a 20" wheel and tada
a couple of wheel stands then once the trike is built to a point where i dont need the stands any more i will trim down the axle on the side of the stand the free side is where it will connect to the trike im also going to make a couple of other jigs up as i did struggle with MK1 on my own some parts are easy to clamp but a lot are very hard if not impossible to get clamps around due to the size, shape and even angel that there at. one thing i can recommend for anyone thinking of doing a build themselves get your mates around to help the more hands to hold bits the better, or if your a billy no mates like me
then the best things you can buy are the magnetic welding clamps if i didnt have a couple of them i would really struggle.
anyway hopefully depending on the weather and on how i am i will get the frame started tomorrow so fingers crossed
stuee
