Kell
- High Wycombe/London
I'd also add that not all multi-tools are the same.
Most will get you home in an emergency, but the el cheapo one I bought a while back doesn't lock any of the tools in place when they're pulled out. The other one I've got (not sure of brand) does at least lock the spanners in place.
It's surprisingly difficult to use an allen key or screwdriver, when the 'handle' flops about.
And your 15mm spanner should be able to give you enough leverage to remove a wheel nut that's been on through a UK winter.
