Into my lungs I'm guessing.
Horrible isn't it.
Fairy liquid.
Then your car can blow lovely sooty bubbles as you drive along....
Never mind what big Ed saysTerraclean.
I have no experience in it so will bow you your judgement if you've seen it in action, but I can understand that if you drop an item into a solution it will work, but what I'm not so convinced on is if you shove the stuff into the engine, where does all the crap go? Out through your CAT/DPF etc. which can't be good for them.I have no connection with the product at all, I was just offering up my experience.
They fill up from the same refinery but the driver has additives that can be added to the fuel on delivery, depending on whether the retailer pays for it or not.
I've used Redex in the past - and oddly the cheapest place to get it has been Tesco...
That said, what fuel are you using? If it's cheap supermarket diesel it might not be doing you any favours.
I found that Morrisons diesel in particular was prone to giving a lumpy lumpy tickover and slightly hesitant running. Switching to Shell / BP sorted it and I haven't filled up at Morrisons since.
Try running a tank of BP Ultimate or Shell V-Power Nitro Plus (or whatever it's called this week) diesel through it as well.
As has also been said, a few miles of motorway running at over 2,500 rpm will help too - this may mean keeping it in 4th gear.
Or do what I've done and ditch the diesel and buy a petrol engined car.
(However someone will be along shortly to rubbish everything I've said above... )
Rubbish rubbish rubbish..and futhermore that's just rubbish
I try to help out on Saturdays
