Cycleops
- Accra, Ghana
I suspect they will work with 180 rotors as my front is that size and the Tektro calipers have simply had spacers added to bring them in line. Nothing in TRPs pdf installation document about rotor size. Maybe I’ll buy a 160 just in case.I got the info from Chain Reaction,
Answer:
- Staff
This road disc brake caliper is developed for use with 140mm or 160mm rotors only as these are the common diameters used on Road bikes with Disc brakes. These calipers are intended to be use with Road Drop Levers.
A 200mm rotor diameter would be too large to be accommodated on a road bike.
http://www.chainreactioncycles.com/trp-spyre-mechanical-2-piston-disc-brake/rp-prod143623
