Rear Wheel Wobble
Vapin' Joe
Formerly known as Smokin Joe
Bent spindle. Replacement needed.
PatrickPending
Leicester
Only ever known them snap completely, remove cones and nuts on ne side - it should pull out. Either take old one to LBS for a an exact replacement or order off interweb. Whilst you're at it you may as well re grease and service the hubs..... oh and try not to lose the bearings....
Tim Hall
Crawley
I can't see from the video whether the spindle is hollow or solid, but the solid ones were prone to bending.
What @Smokin Joe said. For reasons of SCIENCE, solid ones aren't as strong as hollow, I can't remember excatly why, but did read an excellent beginners book about Materials once in a quest to learn. Can't remember what it's called now.
I was out on a ride with a mate on his BSO which suffered the same fault. We stopped at Thee Pubbe for refreshment and bike fettling. I spied a discard pick axe handle lying in the bushes and twatted the end of the spindle with it. Lo! It was straight again.
Garethgas
What @Smokin Joe We stopped at Thee Pubbe for refreshment and bike fettling. I spied a discard pick axe handle lying in the bushes and twatted the end of the spindle with it. Lo! It was straight again.
Unfortunately, engineers of your calibre are becoming a rare breed.
Is 'twatted' a technical term?
Keep up the good work ^_^
