Rear wheel not stable
format
Glasgow.
So I took the rear wheel off my bike to patch a puncture, and now that the tire is back on and the wheel is screwed back on (it's a screw, not a quick release), there seems to be a bit of give in the wheel.
I can see it move ever so slight from side to side if I push/pull it, and it wasn't like that before. I've tightened the bolts either side as much as I can, so I'm not sure what the problem is. The middle of the wheel doesn't seem to move, but the rim does.
It's a single speed by the way, if that helps.
Help appreciated :smile:
Zoiders
Some cup and cone bolted wheels can unwind the cones if you over tighten them.
You have pushed the cones apart like a car jack.
Failing that if you are sure the hub is solid then maybe you need to re-tension the wheel as one or two loose spokes can lead to an entire wheel going pringle shaped, you will find some give in it though, it's a spoked wheel that flexes, not a solid cast iron wheel.
As Zoiders say it may be simply a case of natural flex.
As a general rule-
A Cone issue will usually allow a little bit of movement with not very much pressure on the rim but the rim won't move too far out of line.
With a flex issue the rim doesn't move under light pressure but will move a bit further under pressure than the first case.
