Last week, while cycling up a steep hill to get home, my bike experienced a fault which no-one (including the mechanics at our local bike shop) can properly explain. What happened was that the bike came to a dead halt in the road. I got off, had a look, couldn't find anything obviously wrong, got back on the bike and carried on cycling, only to have the experience repeated again. . . again. . . and again. Deciding I needed a new chain and cogset, I took the bike into the shop to have the work done, and in addition ended up having a new back wheel, plus a replacement middle ring on the bike's triple chainset. Fine, except the fault continued. So back to the shop whose friendly staff suggested that the problem could be due to the rear wheel's skewer shifting under pressure, causing the tyre to rub against one of the frame's rear stays. At any rate, they replaced the (temp) QR skewer with a nutted one, and there has been a mild improvement.
Nevertheless, the problem still persists; that's to say the bike 'locks up' when I'm cycling uphill in bottom (20") gear. In fact the problem becomes exponentially worse if I attempt to get up the hill in any higher gear. Also, there's this: I've had tyre rub before on other bikes (in the distant past), so I know what that feels like. This is different in that I'm talking about a sudden dead halt, and I real do mean sudden. . . like it feels mechanical not frictional, which strongly suggests that it's something to do with the transmission. A tyre rub would give me fractional warning time, all the more so since I'm only doing 4 ~ 5 mph whenever it happens. So what can be the cause of the fault? I've checked the 26T innermost chainring and it looks fine. Could it be something to do with the rear deraileur, the jockey wheels perhaps? Can't be due to the new chain and cogset, not if they're replicating the fault during the bike's previous transmission setup. So what the hell is going on? In short I'm completely foxed! Any ideas therefore will be greatly appreciated.
Apologies in advance about the length of this post. . .
My 'best' guess would be chain suck: ie the crank suddenly was 'stopped' "the bike came to a dead halt"
