Biker Joe
- Nr Harlow, Essex.
I have a Carrera 'Vanquish' road bike. The stock wheels are OK. Built up they only weigh 1.8kg and run true.
The only problem is that the rear wheel has this really thick grease packed into the ball and cone bearings that's creating a drag when you turn the hub.
I've loosened the cones a little which helped a bit.The bearings still drag however.
The wheels are only a few weeks old so the bearings shouldn't be worn.There is no roughness.
Do you think it would be worth repacking the bearings with a lighter grease and if so what grease should I use?
The front wheel is fine, by the way, and seems to have the same grease
