Have you tried switching the rear pads with the front ones to see if that makes a difference at either end? Rear brakes suddenly become good and fronts bad = your pads are the problem
No difference at either end = pads are fine look for something else.
I'd be very surprised if the frame parts of the bike were flexing enough naturally to cause this problem. I'd have a seriously hard look for cracks or failed joints & let an experienced bike mechanic do too. If the frame is broken in some way, it could be a weld repair to a crucial safety part or a new bike at that price.
Discounting frame failure
As it stands the lever can be pulled around half way to the handlebars when braking fully, but no joy in locking the rear wheel no matter how hard I pull on it
If I understand this bit right, you pull on the lever and once its at half way you can't pull it any further even though there would be freedom and range to do so if the rear wheel wasn't in place?
i.e. The brake pads are pressed to the rim before the travel of the brake lever is exhausted?
If so then you have a problem with your pads or rims having some sort of contaminant that is basically lubricating the contact surfaces and destroying your braking efficiency.
Have you spray oiled/lubed the chain or sprayed oil anywhere near the bike recently?
Job 1: have the rear pads and rim off and thoroughly scrub them clean with degreaser.
Job 2: put it back together and 'toe in' the brakes : from above the brake pads should look like this: / \ :front end of the pads angled in by 1-2 mm more than the rear so as the wheel rotates, the front of the pad contacts the rim first and the momentum of the wheel helps pull the rest of the pad hard onto the surface.
Pads flat fitted: I I will cause the pads to judder & squeal, making a bit of a drop off in braking
Worst of all: \ / :badly fitted or unevenly worn front to back will be actively pushed off the rim as the wheel rotates and seriously reduce braking performance.
Assuming not a faulty frame and if correctly fitting &/or the pads off the front fail to improve braking at the rear, off the top of my head you could consider
Contaminated rims.
Solid fitted mudguards catching the top of the V arms & stopping them moving freely?
Cracked V brake arm only shown when pulled on?
Incorrectly fitted/badly kinked/trapped cable & /or outer - you've not cable tied something to one of the tubes that has trapped the cable (A decathlon mechanic setting up daughters new bike trapped the rear derailleur cable under the kickstand he tightened up).
Faulty brake lever or the flappy cable end holder not having been aligned properly?
Although if the front pads do work well on the back, most of the above will have had to work properly too and you're stuck with contaminated rims.
