mickle
innit
- 53.933606, -1.076131
The thing is, the quality of the frame, the method of construction, material and the indivual frame components can differ enormously. I've cold set frames which required two big lads jumping up and down on the rear triangle, and others which could be reset with two bare hands (muddy fox courier). One of the worst things you can do to a hub (particularly an internal geared hub) is bolt it into a pair of dropouts which is not totally parallel. So anyone can cold set a rear triangle to give a different OLND but it's no use if you've not bent both stays equally. Because you've now got a bike that crabs sideways. And if your dropout faces are not parallel you're bending the axle, putting a damaging load on your hub bearings which will shorten its life. Bike shops don't charge 'hundreds' to cold set a frame, and there's more to it than just cranking it open with a car jack.
